FAST Fabrication 94 b4000 turn into SNORE class 7 race truck build thread
Show off your ride or recent upgrades. Post your pictures in here.
Postby ChaseTruck754 » Fri Jun 18, 2010 1:30 pm
I've never worked on it. MIG's aren't allowed to touch the stuff I do :wink:
I just remember watching all the posting on DR and then the 1,500 "how do you do this" posts that came up. I guess that could have been a clue you guys were working on it, but I knew at least 2 fabricators touched it. I just didn't know the 2nd was "FAST Fabrication"
Have you flown in a ford lately?
Because lord know's it's been waaaay too long since I have!
bajablood wrote:Steve has balls.. I like balls.
ChaseTruck754
Postby FAST Fabrication » Sat Jun 19, 2010 12:07 am
1500 a lil exagerating maybe 15.... actually our certified welder just got a tig two months ago... and you will see some tig work on the truck, mostly on the parts were going to sell... We are building a 4 link jeep wranger crawler for him, using an old chevy motor and front and rear axles, design it himself only thing he bought were poly upper pockets, a lil side project of his. As far as the second fabricator, we didnt have a name but when we finally got the truck to our place in AZ and started learning stuff and realize we were doing better (I should say more accurate) since one man of team is a tape measure/level crazy guy then the previous builder and we started get inquiries about work, we decided to have a Fabrication divisionm of my Corporation FAST Industries which incorporates Team FAST Racing, FAST Apparel kind of got put on the back burner with school and truck, and now FAST Fabrication and working on FAST Marketing & Web Development..
but prior to us only one shop worked on it, I know at first he had an engineer who worked on it under him who designs some awesome toyota kits and has a bad ass ranger (socalmoto) i believe is his name but the shop cut out the cage he had made (or help made)... and then I believe the shop also had another fabricator who does his own garage work and works at PP help in back half, but these were all done while under the name of the previous shop so it is consider just one Fabricator prior to us.
We also have only really been working on it since April and you can see the amount of FABRICATION we have done compared to the amount done by the previous shop that had it for 11 months... but thats enough of that time to get back to progress
www.fast-fabrication.com www.myspace.com/fast-fabrication www.facebook.com/fast-fabrication
Team FAST Racing would like to thank its sponsors FK Rod Ends, Glassworks Unlimited, Sway-A-Way, The GMR, Raceline Wheels, General Tire, Vision X, PRP Seats, Optima Batteries, Suspension Springs Specialists
FAST Fabrication
Postby FAST Fabrication » Sat Jun 19, 2010 11:27 pm
Got the Sway bar all mounted up and built a sweet dimple gusset plate, just need to fully weld it...
started on fuel cell relocation, built a gusset plate for back of frame will have a dimple in it and have front mount to fuel cell welded to it
also FAST Fabrication has got their Facebook page and business page up and working on myspace and twitter page then the website. We are doing a $250 basic bumper special just like the one on the 2001 A-Arm ranger. Also working on getting finished models of our jack skids and light bars all at unbeatable prices.
FAST Fabrication
Postby FAST Fabrication » Mon Jun 21, 2010 11:27 pm
got lower link arm for sway bar pocket done and level out housing for bump pad
bump cans fully welded
rear gusset which also was used to mount fuel cell due to relocation
fuel cell back in
sway bar mount
FAST Fabrication
Postby FAST Fabrication » Sat Jun 26, 2010 7:47 pm
you can now follow FAST Fabrication and the other division of FAST Industries as well as our builds and product releases at myspace.com/FASTfabrication and facebook.com/FASTfabrication and twitter.com/FASTFabrication, add us and join the FAST team
FAST Fabrication
Postby FAST Fabrication » Sun Jul 04, 2010 1:51 am
how far off driveshaft needed to be extended at ride height... getting custom one made
full droop, roughly 35" of useable wheel travel, going to strap at around 25
bump, where can will will hit on axle
fuel cell clears now
spare mount is done, finishing fabricating the spinners
sway bar completed, going to add a quick disconnect pin set up
cpl dooped pics of A-arm ranger, working on front bumper for a explorer and frontier this week for customers
thanks to our sponsors PRP Seats at prpseats.com
FAST Fabrication
Postby FAST Fabrication » Tue Jul 13, 2010 6:46 pm
Welded and completed sway bar, bump stops & pads
spinner parts welded, still need to weld handle bar, studs, and lil gussets
Axle painted, extended stock driveshaft in, suspension fully bumped plenty of clearance
from back half
from fuel cell
from battery box/differential
and from wishonbe and backhalf
Vision X lights...one 9" and one 7" to mock up light bar and bumper, work light is insanely bright comes with car charger and wall charger, poly-cabronate lenses
found tall jackstands for $60 each after ship
old shock mount pockets before cut
passenger side after cut
think i will call my truck the grasshopper or locust lol
bypass will actually be an 1" taller and coil-over 1" taller from before, causing us to need 90 degree resi fitting.
FAST Fabrication
Postby FAST Fabrication » Thu Jul 15, 2010 11:41 pm
Spinner and spare tire is done, just waiting on shock ends to finish shock mounts, then rear is done until fuel cell decision is made...
think were going to do a front mounted light bar... with 5 6.7 vision x lights
changed to blue.... only having suspension parts grey
still pushing on just waiting for parts from sway away and tech guy from MDR/MORE/LORE/etc to come check cab cage and fuel cell and rest of truck he said for sure mon or tues, so once that is done we can actually continue full on with truck figure out our options with fuel cell and go from there. School starts again 21 next month so got to get as much as I can done.
FAST Fabrication
Postby FAST Fabrication » Mon Jul 19, 2010 11:08 pm
old bedside mounts
new mounts, glass out further in the back, amd 1" 5/8 gap at bump
here is the glass mounted, there is a slight gap in bumper, but tech guy told me need to cut the hook off so there will be plenty of room..
future plans if/when bedsides break or mount breaks plan to cut bend out of front and go straight across like rear and change the previous tabs to the longer plate tabs, also plan to put a 4th in the rear on top but a hood pin not a dzus fastener so easy to set on straight and keep wait off fastener
shock parts showed up tonight, tomo we dissamble the shocks and work on building the new rear mounts, then the rear is finished minus plumbing and whatever happens with fuel cell
FAST Fabrication
Postby FAST Fabrication » Fri Jul 23, 2010 9:16 pm
Here is FAST Fabrication custom shock mounts prior to weld and over lay plate. These were completely designed by a Master Carpenter not a Fabricator and has never claimed to be one, he built the whole thing with (Jigsaw, Grinder, Cut-Off, Drill, Hammer, Vise, Tape Measure, Level, Plumb Bob, Clamps, and Welded) the thing is perfect, shocks are correct distance, completely vertical ends do not rub anywhere on trailing arm and spacers are same distance, and shock mount follows same plan as trailing arm. Over lay plate is getting cut tomo then I am going to see about getting letters cut into it by CNC otherwise will do it with a drill, jigsaw, and die grinder.
In your guys opinion does it look strong enough, its 1/8 plate has one vertical rib on the inside, may box bottom corners or put vertical wedges at the bottom to if you think it needs it. It was very difficult took 2.5 days lots of going back and forth to the grinding with the compound angles and then the driver side tubes being half inch in. We were able to keep it symetrical from distance to tube and mounting position, only difference from back you can see a lil top edge from inside plate on driverside, tube is 1/2" off but turns into about 1/8" because shocks are stagger because trailing arms do not go straight back they go at an angle.
the previous one, I cant show the tape measure pictures maybe in the future
just finished pass side today
FAST Fabrication
Postby FAST Fabrication » Wed Aug 11, 2010 9:02 pm
FAST Fabrication built explorer basic bumper
Took the boat out for the first time, it was super busy and windy
A look at the truck in the garage/shop
Shock mounts fully welded and overlay plates should be here tomo or friday from R&I
weld on resi mounts, tilted for a reason
bedside plate, for strength and race number stickers
Rear limit straps completed, strapped at 25" for now
Spare tire mount is completely done, we made new tabs to raise the front to keep tires off batteries as well as give more room to put filler neck in between cell and rack
Added a tube cap to finish rear off besides paint and plumb/electrical...on to cab in next day or two after we finish welding a few things
FAST Fabrication
Postby FAST Fabrication » Wed Aug 11, 2010 9:25 pm
Took our damage 32 gallon jaz jeepspeed cell got a new blank bladder and sending unit completely dismantled the damage one, clean the tacks and edges and burns off the skin, cut the new holes in the blank and transfer all the parts including the foam.. Then using a piano hinge we attached both sides together allowing it to come apart as well as fit in ranger frame rails or at least our spot, its maybe a 1/8" wider then the actual box and hats only at the hinge part were before you had 1/2 flanges on both sides
first we drilled holes from inside and did a spot/tack weld just like jaz does, but we decided to add small beads on outside and edges just in case.
Image\
finished product, took about 9-10 hours
FAST Fabrication
Postby FAST Fabrication » Wed Aug 18, 2010 9:57 pm
Finished the back panel, the ends were hard without metal shaping tools to match compound bends... So we did our best did not worry about having a straight line on bottom, didn’t matter because we had to cover up the square cut our on driver side.... looks good and hella strong, the 1" tube that they put between cab fell out as we were welding the cage to the plate, so might not bother with cutting a hole and running a tube to frame and floor.
The tube that was sitting in there
not sure if anyone has ever done this, but I came up with an idea to help with the scoop getting air to the coolers, but more so to strengthen the corner/back of cab were 2 pieces were cut out on each side (guessing because first cage was removed) and I myself welded the insides closed back together as far up as I could get the nozzle in and the driver side the gap between them was just too big, got tired or trying to bridge a 1/4" plus gap. So this piece welds to sliding glass window edge (were both pieces were cut from so adding a piece to weld not only the two pieces to the plate but also to outside skin, and then it goes to the extended cab window edge pass were the cab was cut off so strengthening that as well) It is super strong I like it, would of put dimples or our name in it, but then defeats purpose of pushing air through smoothly
Seat harness are done
I had a question on the seat mounts; we have the front tube that we made hoop over the tranny hump. Because of how far the cage is from the side, the seats sliders only allow for one notch movement because of b pillar on back movement and hoop over tranny on front mount. Do you have to have two bars going all the way across, or can I cut the hoop part and weld a plate from the front floor bar to either back bar or the cab floor were stock front seat mounts were?
We got the engine oil cooler in yesterday will be getting lots of parts these next weeks, I pick a different color for the truck going with one single color will show it at the expo. Along with our fiberglass dash/scoops/and visor. I think we are going to make a mold for a visor and sell them cheap, even cheaper if you don’t want gel coated.
FAST Fabrication
Postby FAST Fabrication » Thu Aug 26, 2010 6:24 pm
mounting our shoes
Thank You tp General Tire visit them at GeneralTire.com, I am very pleased with these competition tires.. no bulge whatsoever, was woried about my track width and it actually gave me more clearance. Highly recommend you check them out.
Thank you Allied/Raceline wheels, you can visit their site and see all their beadlock wheels and truck/suv wheels at racelinewheels.com The ring seats great on the tire and we are very happy with our change and happy we are using 17" wheels.
they weigh 125lbs a wheel mounted
FAST Fabrication
Postby FAST Fabrication » Thu Aug 26, 2010 7:26 pm
window net kit only using top bar
pci race air
new trailer
our shock plates
FAST Fabrication
PreviousNext
Return to Show and Tell
