93 ranger build
Show off your ride or recent upgrades. Post your pictures in here.
Postby mxraycer » Sun Dec 09, 2007 7:59 pm
"go big or go home"
mxraycer
Postby B Leonard » Sun Dec 09, 2007 8:59 pm
nice garrett looks good
B Leonard
Postby lasdracing » Sun Dec 09, 2007 10:00 pm
First off I am not trying to be a dick or anything but is the radius arm going to clear at full bump with the stock transmission cross member?
Thanks, looks like a great start!
-Spencer
lasdracing
Postby 951PRERUN » Sun Dec 09, 2007 10:15 pm
lasdracing wrote:First off I am not trying to be a dick or anything but is the radius arm going to clear at full bump with the stock transmission cross member?
I don't think it will...simple fix though....make a new one....
Looks good
you need to get that stuff boxed and tacked so we can tig it!, I'll be home the 22, 23, 24
YOU KNOW YOU HAVE ENOUGH HORSEPOWER WHEN YOU NEED MORE TRAVEL
951PRERUN
Postby deluxfab » Mon Dec 10, 2007 11:56 am
hey garret its matt, i sold you the beam mounts, solo uses giant beam mounts on thier kits. they look the same because they are the same. truck looks good.
deluxfab
Postby mxraycer » Mon Dec 10, 2007 12:39 pm
yeah thats what i thought matt... yeah i know those radius arms will most likely not clear.... havent even cycled it yet, especially once i finish plating and boxing them... but i already planned on making a removable tranny cross-member... just not sure how i want to do it yet and if i want to try and tie it into the radius arm mounts. i would have more done but it took me like 1-1/2 hours to get those bungs on the heims due to little nicks/scratches in the threads that they came with.
"go big or go home"
mxraycer
Postby mxraycer » Mon Dec 10, 2007 7:09 pm
"go big or go home"
mxraycer
Postby alfredo » Sat Dec 15, 2007 4:57 pm
any more updates?
alfredo
Postby mxraycer » Wed Dec 19, 2007 8:07 pm
took me waaaaaaay longer than i expected to get these triangular pieces done with the right angles/notching... but now the beams are finally ready to be welded up...
"go big or go home"
mxraycer
Postby 951PRERUN » Thu Dec 20, 2007 6:34 pm
Looks good....are you ready to do a lot of welding?
951PRERUN
Postby mxraycer » Fri Dec 21, 2007 11:36 am
ohh yeah.. probably gonna take forever!
"go big or go home"
mxraycer
Postby alfredo » Fri Dec 21, 2007 8:49 pm
hey not to bash you but i have built king pin beams the same way. what i recommend is that you remove that top plate on the beam. take a flap disck or something and grind down the original radius arm boss. cut a new a plate that is longer so you can bend it to the contour of the "s" in the beam. theirs isnt a that much surface area where you fab'd parts come together withe the beam end.
i did it the same way my first time and the beam cracked when i came down hard on the passenger side.
alfredo
Postby 951PRERUN » Sat Dec 22, 2007 12:01 am
Thanks for the input! wait tell you see the finished product :D
951PRERUN
Postby mxraycer » Sat Dec 22, 2007 11:29 am
yeah. i was kinda worried about that too.. thats why i have a master welder by the name of charles and some gussets that are added as well to take care of that..
"go big or go home"
mxraycer
Postby alfredo » Tue Dec 25, 2007 11:42 am
Any more updates?
alfredo
PreviousNext
Return to Show and Tell
