Erik's Class 12 Car
Post VW tech, projects, and questions here. If you've got a beam and an air-cooled engine, this is your place to post.
Postby ErikIrvine » Tue May 21, 2013 2:56 pm
Haha! I was wondering where you were going with that long story
ErikIrvine
Odds say 13:5
Postby Marland » Tue May 21, 2013 3:54 pm
Seams legit. You 2 are a day late and a dollar short to the SS 12 party. It's ok, I wouldn't want to hurt your egos too badly with all you guys expeareance compared to myself. ;)
Marland
Postby 3GTech » Tue May 21, 2013 9:50 pm
Do I hear a challenge to Eric and Zac???? lol jkjk
The properly crossed thread will never come lose.
3GTech
Postby bajablood » Wed May 22, 2013 7:26 pm
Marland wrote:Seams legit. You 2 are a day late and a dollar short to the SS 12 party. It's ok, I wouldn't want to hurt your egos too badly with all you guys expeareance compared to myself. ;)
More like your car self destructed too early. Too bad you wont have a gun for the title fight. No doubt Eric and I are going to have to dual. We will probably settle it outside of a race and who evers car is slower which will most likely be mine one will have to go to the drawing board for a little more pep in the step. For a little more of an even playing field.
bajablood
Postby Baja Stu » Wed May 22, 2013 7:36 pm
You could bump up the compression and get a plenum.
Cross threading is as tight as Loctite
Baja Stu
Postby ErikIrvine » Fri May 24, 2013 11:24 am
Whats the difference between a plenum and non-plenum motor? Are there other mechanical changes that are made other than the intake & tuning? Is there an hp difference or power curve change only?
ErikIrvine
Odds say 13:5
Postby ErikIrvine » Fri May 24, 2013 11:26 am
Zac, I talked to Jimenez before I started the engine to get break in rules, I asked him if he had a build sheet on the engine, he said the CR is 11:1 & to set valves at 0.006. Same as yours?
ErikIrvine
Odds say 13:5
Postby Baja Stu » Fri May 24, 2013 3:22 pm
Most guys with chromo pushrods go .000
Baja Stu
Postby J.Johnson » Fri May 24, 2013 4:51 pm
Make a plenum! you have one to copy don't you :)
J.Johnson
Postby ErikIrvine » Sun May 26, 2013 8:57 am
Stu, I asked Jimenez and he said .006... I asked zero tolerance and he said no, .006.
ErikIrvine
Odds say 13:5
Postby bajablood » Sun May 26, 2013 12:13 pm
I'm gonna give that a try. I could see how zero tolerance could add contract pressure to the rocker assembly.
bajablood
Postby ErikIrvine » Sun May 26, 2013 3:20 pm
Does anybody crack check their CV cages or does everybody just visually inspect them and the stars, cages etc.?
ErikIrvine
Odds say 13:5
Postby Baja Stu » Sun May 26, 2013 4:46 pm
I mag all of mine. But the problem with the cage is that it gets a wear mark that rolls up a small lip of material that looks to be a crack but it is not.
Baja Stu
Postby ACME » Tue May 28, 2013 9:28 am
Crack check stars and cages, axles and everything else...
Plenum vs non Plenum = 2 stroke vs 4 stroke. Higher freer rev, more top endy in the Plenum we had and the non was more bottom end not as pipey. Plenum finikier (sp?) on the jetting; Jorge maintained both and does a killer job! You got a great car and fun to drive, we added a bypass that Kent built on my 10 car that had the same rear set-up and it killed it! I know Kirkmeyer-Fiber-Care Racing changed my old 10 to Kings and may still have the old hand built Kent shocks they want to off that'd bolt right on and that there would be killer...
ACME
Postby ErikIrvine » Wed May 29, 2013 7:58 am
Please excuse the rather large business card image I have at the bottom of my posts.....need to find some work. Any help would be appreciated!
ErikIrvine
Odds say 13:5
PreviousNext
Return to Buggies and VWs
